Battery
2 Answers 1 Score |
Can I remove MDM after I already completed a fresh install? |
10 Answers 26 Score |
Is the SSD upgradeable in the 2017 version? |
1 Answer 0 Score |
How do I locate the ssd in the A1707 MacBook Pro |
12 Answers 11 Score |
Left speaker is not the same as the right speaker output |
Parts
- MacBook Pro 15" Retina (Late 2016-2017) Battery
- MacBook Pro Touch Bar (A1706, A1707) Key Caps
- MacBook Pro (A1706/A1707/A1708/A2141/A2159/A2289) and MacBook Air (A2179/A2337) Plastic Feet
- MacBook Pro 15" Retina (Late 2016-2019) Left Fan
- MacBook Pro 15" Retina (Late 2016-2019) Trackpad
- MacBook Pro Retina (A1706 & A1707 Late 2016-2017) USB-C Board
- MacBook Pro 15" Retina (Late 2016-2017) Display Assembly
- MacBook Pro 15" Retina (Late 2016-2019) Right Fan
Tools
- Pro Tech Toolkit
- Spudger
- iOpener
- Tweezers
- iFixit Opening Picks (Set of 6)
- Suction Handle
- TR8 Torx Security Screwdriver
- iFixit Adhesive Remover
- P5 Pentalobe Screwdriver Retina MacBook Pro and Air
- T5 Torx Screwdriver
- Halberd Spudger
- T3 Torx Screwdriver
- P2 Pentalobe Screwdriver iPhone
- iFixit Safety Glasses
- Nitrile Gloves 100 Box
Models
A1707 (EMC 3162 MacBookPro14,3) 2.8 GHz, A1707 (EMC 3162 MacBookPro14,3) 2.9 GHz, A1707 (EMC 3162 MacBookPro14,3) 3.1 GHz
Technical Specifications
Platform
- CPU: 2.8 GHz quad-core Intel Core i7 (configurable up to a 3.1 GHz Core i7)
- RAM: 16 GB of 2133 MHz LPDDR3 onboard memory
- GPU: Radeon Pro 555 with 2 GB of GDDR5 memory (configurable up to Radeon Pro 560 with 4 GB of GDDR5 memory)
- Storage: 256 / 512 GB PCIe-based onboard SSD
Display
- 15.4-inch (diagonal) LED-backlit display with IPS technology; 2880-by-1800 native resolution at 220 pixels per inch with support for millions of colors
- 500 nits brightness
- Wide color gamut (P3)
Ports and Connectivity
- Four Thunderbolt 3 (USB-C) ports with support for:
- Charging
- DisplayPort
- Thunderbolt (up to 40 Gbps)
- USB 3.1 Gen 2 (up to 10 Gbps)
- Wi-Fi: 802.11ac Wi-Fi wireless networking; IEEE 802.11a/b/g/n compatible
- Bluetooth: Bluetooth 4.2 wireless technology
Camera: 720p FaceTime HD camera
Audio
- Stereo speakers with high dynamic range
- Three microphones
- 3.5 mm headphone jack
Battery and Power: Built-in 76.0 watt-hour lithium-polymer battery
Size and Weight:
- Height: 0.61 inch (1.55 cm)
- Width: 13.75 inches (34.93 cm)
- Depth: 9.48 inches (24.07 cm)
- Weight: 4.02 pounds (1.83 kg)
Operating System
- macOS High Sierra
- Touch Bar runs a modified version of watchOS
